Stary 13-12-2017, 07:49   #1
Hooch180
Imię: Maciej
Zarejestrowany: 05-03-2017
Model: Ford Mustang GT 2019 EU
Silnik: 5.0L TiVCT Coyote (450KM)
Postów: 1,165
Unhappy Auto zaczęło zamulać. Kod P2008 - IMRC Circuit/Open (Bank 1)
Witam wszystkich. I mnie dopadło tym razem.
Wczoraj zauważyłem przy próbie ruszenia z pod świateł, że nagle zaczął zamulać. Dojechałem do mieszkania. Dzisiaj rano zauważyłem check engine.
Dokładne logi z jazdy (do otwarcia w programie FORScan) do pobrania tutaj (w katalogu "Wykresy FORScan"):
Tutaj jest log (wywaliłem moduły bez błędów):
Kod:
===PCM DTC P1463-63===
Code: P1463 - AC Pressure Sensor Insufficient Pressure Change
Additional Fault Symptom:
 - Signal is Above Maximum Threshold
Status:
 - DTC Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
The AC system pressure has not risen sufficiently since the AC compressor was switched on.
This DTC may be caused by :
A/C system fault
Suspect A/C pressure sensor.
Faulty or damaged PCM.
===END PCM DTC P1463-63===
===PCM DTC P2008-E3===
Code: P2008 - IMRC Circuit/Open (Bank 1)
Status:
 - Malfunction Indicator Lamp is On for this DTC
Swirl control output open circuit, short circuit or driver fault.
Open or grounded circuit.
Signal circuit shorted to VBATT.
===END PCM DTC P2008-E3===
===OBDII DTC P2008-C===
Status:
 - Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P2008-C===
===IC DTC U1900-20===
Code: U1900 - CAN communication bus fault
Status:
 - Previously Set DTC - Not Present at Time of Request
Module: Instrument Cluster
CAN Communication Bus Fault - Receive Error
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END IC DTC U1900-20===
Zanim oddam auto do mechanika mam kilka pytań:
  1. Czy ktoś wie co to może być konkretnie?
  2. Czy coś mogę łatwo samemu sprawdzić?
    I kilka dodatkowych pytań:
  3. Czy temperatura płynu i głowicy nie jest za niska (3. wykres z autostrady)?
  4. Czy sygnał z pedału gazu jest OK (jest nieciągły, @[Tylko zarejestrowani użytkownicy widzą linki. ] Ty pewno wiesz)?
Hooch180 jest offline   Odpowiedź z Cytatem
Stary 13-12-2017, 09:06   #2
Autopros
Zarejestrowany: 29-07-2015
Model: Focus MK3 Estate Champions Edition
Silnik: 1,6 TDCi 115
Postów: 113
Domyślnie Odp: Auto zaczęło zamulać. Kod P2008 - IMRC Circuit/Open (Bank 1)
P2008 - Intake Manifold Runner Control Circuit, czyli problem z kolektorem dolotowym. Kolektor ma klapy zapewniające zmienną długość kolektora dolotowego, przez co zwiększa się elastyczność. Masz problem z siłownikiem sterującym tymi klapami, albo zatarła się ośka w kolektorze.
Autopros jest offline   Odpowiedź z Cytatem
Stary 13-12-2017, 09:42   #3
Hooch180
Imię: Maciej
Postów: 1,165
Jeździć chyba z tym można do chwili wizyty u mechanika.
A co do pytań 3,4 ktoś coś mi podpowie?
Stary 13-12-2017, 14:24   #4
Hooch180
Imię: Maciej
Postów: 1,165
Bump.
Czasy w strefie GMT +1. Teraz jest 01:10.
