Stary 17-01-2018, 13:46   #1
Damiankox
Zarejestrowany: 14-01-2018
Model: Focus c-max
Silnik: 1.6i
Domyślnie 1.6 benzyna rozkodowany vin pomoc w tlumaczeniu
Witam. Rozkodowałem sobie VIN, a że tłumacz mi pisze bzdury chcę zapytać czy e liście wyposażenia jest tempomat i czujniki parkowania?
03F1
IGNITION KEY TYPE: IGNITION KEY WITH REMOTE UNIT
17D
PASSENGERS AIR BAG: WITH PASSENGER AIR BAG
844
A/V JACK: WITH A/V JACK
E7F2
PASSENGER DOOR MIRROR TYPE: WITH PASS CONVEX ELEC/HEATED MIRROR
3C42
REAR VIEW MIRROR TYPE: WITH DIPPING REAR VIEW MIRROR
9D9
HEADLAMPS - DESIGN: WITH HALOGEN HEADLAMP
2FB
CENTRE CONSOLE: WITH SMALL FLOOR CONSOLE
07A
WINDSHIELD HEAT SHIELDING: WITHOUT WINDSHIELD HEAT SHIELDING
17A
DYNAMIC STABILITY CONTROL: WITH ELECTRONIC STABILITY CONTROL
07D
DRIVERS AIR BAG: WITH DRIVER AIR BAG
4DC
LOAD COMPARTMENT COVER: WITH LOAD AREA COVER
631
PASSENGER SEAT ADJUSTMENT TYPE: WITH PASS 2 WAY MANUAL SEAT ADJUST
D74
SVO LABEL: WITHOUT SVO APPLICATION/LABEL
0D2
AIR CURTAIN RESTRAINT(RH/LH): AIR CRTN RSTRNT LH
1906
WINDSCREEN WASH/WIPE: WITH VARIABLE INTERMITTENT WINDSCREEN WIPER
409
SKID PLATES: WITHOUT SKID PLATES
C72
SMOKERS PACKAGE: WITH SMOKERS PACKAGE
880
SIDE AIR BAG - PASSENGER SIDE: WITH SIDE AIR BAG - PASSENGER SIDE
B17
ADJUSTABLE FOOT PEDALS: WITH FIXED FOOT PEDALS
399
IN CAR ENTERTAINMENT: HIGH LEVEL WITH CD AND AM/FM RADIO
DED
HEADLININGS: WITH CONVENTIONAL HEADLINING
252
FRONT SEAT TYPE: STANDARD FRONT SEAT
732E
ISOFIX HARD POINT ATTACHMENT: WITH ISOFIX HARD POINT ATTACHMENT
E1A
DOOR LOCKING SYSTEMS: WITH CENTRAL LOCKING SYSTEM
548
GEARSHIFT KNOB: WITH MOULDED GEARSHIFT KNOB
2B9
FRONT PARKING AID: WITH FRONT PARKING AID
DC8
FRONT FOG LAMP TYPE: WITH FRONT FOG LAMPS
855A
DRIVERS SEAT ADJUSTMENT TYPE: WITH DRIVER 4 WAY MNL.SEAT ADJUSTER
0A8
REAR BRAKE TYPE: WITH REAR DISC BRAKES
F21D
LUMBAR SEAT SUPPORT PASSENGER SEAT: WITHOUT PASSENGER SEAT LUMBAR SUPPORT
A00
AUTO HEADLAMPS: WITH AUTO HEADLAMPS
C0A
ANTI-LOCK BRAKES: WITHOUT ANTI-LOCK BRAKING SYSTEM
20F1
FRONT WINDOW OPERATION: POWER FRONT WINDOWS ONE TOUCH UP/DO
BFB
REAR FLOOR CONSOLE: WITHOUT REAR FLOOR CONSOLE
E0D
CONVENIENCE GROUP: CONVENIENCE GROUP NO.6
73AC
INSTRUMENTATION TYPE: CONVENTIONAL INSTRUMENTS - LEVEL 2
3A9
BRAKE EMERGENCY ASSIST: WITH BRAKE EMERGENCY ASSIST
2CA
TINTED GLASS: WITH PRIVACY GLASS
4B5
SPEEDOMETER TYPES: WITH KMH SPEEDOMETER
1E7
RADIO INFORMATION DECODER: (+)RDS
664
RADIO PRE-EQUIPMENT PACK 1: WITHOUT RADIO PRE-EQUIPMENT PACK
F02B
REAR WINDOW OPERATION: POWER REAR WINDOW ONE SHOT UP/DOWN
7C62
REAR SHOCK ABSORBER TYPE: WITH STANDARD REAR SHOCK ABSORBERS
8F5
12 INCH TYRES: 205/55VR-16 BSW TYRE
83A
FAMILY ENTERTAINMENT SYSTEM: WITHOUT FAMILY ENTERTAINMENT SYSTEM
D9A
HEADLAMP CONTROL: WITHOUT HEADLAMP CONTROL
991F
RADIO SPEAKERS: WITH 8 HIGH SERIES RADIO SPEAKERS
B494
HEADRESTRAINT - REAR CENTER: WITH REAR CENTER HEAD RESTRAINT
B30
HEATED WINDSCREEN: WITH HEATED WINDSCREEN
A4A
SPEED CONTROL: WITH SPEED CONTROL
9B3A
STEERING WHEEL TYPE: 4 SPOKE LEATHER STEERING WHEEL
1F2
SIDE AIR BAG - DRIVERS SIDE: WITH SIDE AIR BAG - DRIVERS SIDE
E39
WHEEL SIZE & STYLE: 6.5 X 16" ALLOY - STYLE A
077
TRAILER COUPLING: WITHOUT TRAILER COUPLING
FED
SUN BLINDS: WITH SUN BLINDS
2312
RADIO CONTROLS - COLUMN STALK: WITH COLUMN STALK RADIO CONTROLS
541
ICE FEATURE PACK: ICE FEATURE PACK 6
C01
SECURITY LOCK GROUP: SECURITY LOCK GROUP NO.1
84AA
SPARE WHEEL TYPE: WITH MINI STEEL SPARE WHEEL
EE1
SUSPENSION TYPES: WITH STANDARD SUSPENSION
A5A
GLOBAL CLOSING: WITH AUTO CLOSING WINDOWS
3F6
WHEEL LUG NUTS: NON LOCKING LUG NUTS
0E1D
LUMBAR SEAT SUPPORT DRIVER SEAT: WITH DRIVERS MANUAL LUMBAR SUPPORT
C22
PLANT BUILD REQUIREMENTS: SAARLOUIS PLANT BUILT
FB9
REVERSE PARKING AID: WITH REAR PARKING AID
A372
DRIVER DOOR MIRROR TYPE: DRIVERS POWER HEATED CONVEX MIRROR
CDB
OVERHEAD CONSOLE: WITH STANDARD OVERHEAD CONSOLE
88D
AUXILIARY HEATER: WITHOUT AUXILIARY HEATER
D72
AIR CURTAIN RESTRAINT(RH/LH): AIR CURTAIN RESTRNT LH
23D4
SPARE WHEEL TYPE: SPARE WHEEL - MINI STEEL
Damiankox jest offline   Odpowiedź z Cytatem
Stary 17-01-2018, 13:53   #2
weuek
Zablokowany
Zarejestrowany: 17-10-2014
Model: nie ford, rzecz jasna
Silnik: spalinowy
Postów: 5,927
Domyślnie Odp: 1.6 benzyna rozkodowany vin pomoc w tlumaczeniu
Są czujniki parkowania z przodu i z tyłu (parking aid: front, rear). Tempomat też (speed control).
Ciekawostka: Nie ma ABSu.
Ostatnio edytowane przez weuek ; 17-01-2018 o 13:55
Stary 17-01-2018, 14:25   #3
c-matix
Avatar c-matix
Zarejestrowany: 21-09-2009
Model: Focus C-Max , Fusion
Silnik: 2.0 16v 145KM , 1.6 Tdci 90KM
Rocznik: 2006 Silver Polar, 2006 Jeans Metalik
Postów: 1,811
Napisał weuek Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Nie ma takiej opcji, raczej kryje sie pod oznaczeniem esp lub coś podobnego. Jaki to motor w tym autku.
c-matix jest offline   Odpowiedź z Cytatem
Stary 17-01-2018, 14:29   #4
Damiankox
Model: Focus c-max
Silnik: 1.6i
1.6 benzyna. ABS pracuje więc na pewno jest Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. kurczę bo tempomat nie mogę załączyć po naciśnięciu on nic się nie dzieje, i bałem się czy kiera nie przekladana
Stary 17-01-2018, 14:43   #5
weuek
Zablokowany
Silnik: spalinowy
Postów: 5,927
Tylko piszę, co wyczytałem z tej listy, a tam stoi:
Jak widać, etis nie jest w 100% wiarygodny.
U mnie jest wpis: AUXILIARY HEATER: WITHOUT AUXILIARY HEATER, a grzałka elektryczna jest.
A tempomatu pewnie nie umiesz włączyć. Oprócz ON, trzeba jeszcze wcisnąć środkowy przycisk (SET) i przytrzymać, aż pojawi się zielona ikonka tempomatu na zegarach.
Ostatnio edytowane przez weuek ; 17-01-2018 o 14:46
Stary 17-01-2018, 15:10   #6
Damiankox
Model: Focus c-max
Silnik: 1.6i
W sumie było, że to diesel hehe. Dzięki wielkie Panowie, jeszcze kogoś ogarni3tego od fordow na dolnymslasku szukam Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Czasy w strefie GMT +1. Teraz jest 16:32.
