#21 | |
![]() Imię: Robert
Zarejestrowany: 25-04-2008
Model: Mdo MK3,4,5; Focus MK3
Silnik: 2.0TDCi; 1,4Pb
Rocznik: 2006; 2009
Postów: 1,660
#22 |
![]() Zarejestrowany: 17-10-2011
Silnik: D6BA
Pozwolę sobie odgrzać nieco ten temat jako, że na schematach nie wszystkie bezpieczniki były opisane - np sławny F82...
Poniżej lista bezpieczników wraz z zabezpieczanymi urządzeniami: F1 - 30A - ABS. F2 - 50A - Ignition Relay F3 - 60A - Diesel Engine Heater F4 - 30A - Heated Rear Window F5 - 20A - Heated Seats (Facelift only) F6 - 40A - Heater Blower Relay F7 - 50A - Main Power F8 - 60A - Engine Cooling, Pre-glow relay F9 - 20A - PCM Relay F10 - 40A - Engine Cooling F11 - 30A - Heated Windscreen F13 - 30A - Heated Windscreen F15 - 3A - Heated Windscreen F16 - 20A - LH Xenon Headlight - 7.5A - LH Halogen Headlight F17 - 10A - Automatic Transmission F18 - 20A - RH Xenon Headlight - 7.5A - RH Halogen Headlight F20 - 20A - ABS F21 - 15A - Light Switch F22 - 20A - Headlight Cleaning Relay F23 - 7.5A - Battery Backup Sounder ( petrol ) - 15A - Injection Relays, Booster Heater (diesel ) F24 - 20A - Central Timer Unit F25 - 15A - Central Timer Unit F26 - 20A - Horn Relay F27 - 15A - Fuel Pump Relay, Windscreen Heater F28 - 20A - Ignition Switch F29 - 30A - Starter Relay F30 - 7.5A - Alternator F31 - 7.5A - Air Conditioning F32 - 3A - Automatic Transmission, Engine Control Module F33 - 7.5A - PCM Module Relay F37 - 15A - Oxygen Sensor F40 - 7.5A - Engine F42 - 10A - Engine F60 - 25A - Electric Windows F61 - 25A - Electric Windows F62 - 15A - Light Switch F63 - 7.5A - Direction Indicators F64 - 7.5A - Direction Indicators F65 - 7.5A - Air Conditioning F66 - 30A - Drivers Power Seat F67 - 7.5A - Alarm F68 - 15A - Cigarette Lighter F69 - 7.5A - Radio, Instrument Cluster F70 - 15A - RH Rear Power Point ( Estate Models ) F71 - 10A - Rear Seat Entertainment (Video Screens) F72 - 20A - Radio F73 - 20A - Sunroof F74 - 20A - Trailer F75 - 7.5A - Electric Mirrors F76 - 7.5A - Air Conditioning F77 - 7.5A - ABS, Traction Control F78 - 7.5A - Instrument Cluster, Airbag F80 - 7.5A - Automatic Transmission, Reverse Lights F81 - 7.5A - Temperature Sensor, Automatic Transmission, Seat Sensor F82 - 7.5A - Air Conditioning, Windscreen Washer Heater, Booster Heater, Cruise Control F83 - 15A - Heated Seats F84 - 20A - Light Switch F85 - 7.5A - LH Headlight F86 - 7.5A - RH Headlight F88 - 15A - Low Beam Relay, Light Switch F89 - 7.5A - Airbag F90 - 15A - Rear Wiper Motor F91 - 7.5A - Electric Windows, Dimming Mirror, Sunroof F92 - 10A - Trailer F93 - 10A - Headlights, Brake lights, Heater Blower F94 - 20A - Wash/Wipe F95 - 7.5A - Low Beam Headlights F97 - 7.5A - License Plate Lights, Glove Box Light, Central Timer Unit F98 - 7.5A - Electric Mirrors, Heated Mirrors F99 - Pre-Facelift 7.5A / Facelift 10A - Interior Lights F100 - 7.5A - Multimedia Module ( Inline fuse under the centre console - Pre facelift mondy ) F101 - 3A - CD Changer ( Under the passenger front seat - Pre facelift mondy ) Opisy jak widać w języku angielskim, ale dziś w dobie google translatora nie stanowi to chyba problemu? |
#23 |
![]() Zarejestrowany: 05-11-2011
Postów: 6
Cześć , oświetlenie wnętrza przestało działać , wymieniłem bezpiecznik nr. 99
i dalej nic. Nie wiecie co może być przyczyną ? |
#24 | ||
![]() Zarejestrowany: 08-10-2010
Model: Mondeo MK3 Ghia
Silnik: 2.0 TDDi 115KM
Postów: 112
Tak samo domyslam sie ze jest z radiem bo moje po 1h pracy sie wylacza jesli nie ma kluczykow w stacyjce w pozycji I Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Cytat:
#25 |
![]() Imię: Łukasz
Zarejestrowany: 07-08-2010
Model: mondeo, fusion
Silnik: 2,0 TDDI, 1,4
Rocznik: 2001, 2004
Postów: 8
Witam. całkiem niedawno miałem taki sam problem, sprawdź żarówkę w podsufitce lub jej połączenie u mnie to było problemem.
#26 |
Postów: 6
U mnie nie działają oba światła w środku + bagażnik + pod lusterkami .
To chyba nie może być wina żarówki ? |
#27 | |
Model: Ford Escape/Fusion
Rocznik: 2003/2005
Postów: 6,255
#28 |
![]() Imię: Łukasz
Rocznik: 2001, 2004
Postów: 8
Jeżeli bezpiecznik jest sprawny, żarówka i jej styki ok, to pozostaje problem z czujnikiem od drzwi, choć wydaje mi sie to małoprawdopodobne, ponieważ światło zapala się przy otwarciu nie tylko drzwi kierowcy ale i od pasażera. Być może jest to wina instalacji ale i to bym wykluczył. Pozdrawiam
#29 |
![]() Imię: Łukasz
Rocznik: 2001, 2004
Postów: 8
Przekaźnik działa na zasadzie ograniczenia przekazywanej mocy która nie jest zużywana.
#30 |
![]() Imię: Andrzej
Zarejestrowany: 25-02-2010
Silnik: 140KM
Postów: 11
i dalej nic. Nie wiecie co może być przyczyną ? Witam Miałem to samo w kombi okazało się ze mam przerwaną ścieżkę w listwie bezpieczników elektryk skasował 50 zł za podlączenie na krótko a za zrobienie na gotowo śpiewa 250 zł a na necie znalalem za 65 używana |
