Wróć   Forum Ford Club Polska > Forum Ogólne > Ford Life > Hyde-Park
Stary 14-01-2013, 10:37   #1
websterek
Zarejestrowany: 20-11-2012
Model: Focus C-Max
Silnik: 1.6 TDCI 90KM
Rocznik: 12/2005
Postów: 11
Domyślnie Tłumaczenie Etis
Witam, chciałbym prosić o przetłumaczenie informacji. Dane pobrane ze strony etis.ford.com. U mnie niestety info w wersji angielskiej. Z góry dziękuje.
Minor Features
Saarlouis Plant Built
Security Lock Group No.1
With Convenience Group
Marketing Flex Prep Pack 1
Less SVO Application/Label
Marketing Level 1
Less Electronic Stability Control
Less Global/Auto Closing
Power Front Windows One Touch Down
With Manual Rear Windows
With Tinted Glass All Round
Less Windshield Heat Shielding
Less Heated Windscreen
With Mini Overhead Console
With Small Floor Console
Less Rear Floor Console
Less Special Inter Appliques
With Conventional Headlining
With Load Area Cover
With Dipping Rear View Mirror
Drivers Power Heated Convex Mirror
With Pass Convex Elec/Heated Mirror
With Rear Center Head Restraint
With Drivers Manual Lumbar Support
Less Passenger Seat Lumbar Support
With Driver 4 Way Mnl.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
Less Trailer Coupling
Ignition Key With Remote Unit
With Moulded Gearshift Knob
With Second Remote Ignition Key
With Central Locking System
With Variable Intermittent Windscreen Wiper
Air Crtn Rstrnt LH
With Driver Air Bag
With Passenger Air Bag
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
With Isofix Hard Point Attachment
With Mini Steel Spare Wheel
With Standard Rear Shock Absorbers
6.5 x 16" Alloy - Style A
205/55VR-16 BSW Tyre
Non Locking Lug Nuts
With Standard Suspension
With Mechanical Parking Brake
With Brake Emergency Assist
4 Wheel Anti-Lock Braking System
Less Skid Plates
Standard Front Seat
With Fixed Foot Pedals
4 Spoke Leather Steering Wheel
With Speed Control
With Supplemental Air Heater
Conventional Instruments - Level 2
With KMH Speedometer
With Rear Parking Aid
Less Radio Pre-Equipment Pack
(+)RDS
Less A/V Jack
With Centre Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 2
With 6 Speakers
Less Family Entertainment System
With Column Stalk Radio Controls
With Auto Headlamps
With Halogen Headlamp
With Front Fog Lamps
Less Headlamp Control
websterek jest offline   Odpowiedź z Cytatem
Stary 14-01-2013, 10:44   #2
petrus1
Avatar petrus1
Zarejestrowany: 14-07-2009
Model: Mondeo Mk4
Silnik: 1,6 Ti-VCT
Postów: 685
Domyślnie Odp: Tłumaczenie Etis
Przecież w zakładce na gorze ETIS możesz sam ustawić język. Jest tam też język polski.
petrus1 jest offline   Odpowiedź z Cytatem
Stary 14-01-2013, 10:44   #3
Mariusz
Avatar Mariusz
Zarejestrowany: 19-08-2008
Model: Mondeo Mk3-DENSO
Rocznik: VII/2OO5 Sedan
Postów: 1,941
Podaj VIN i maila w tym wątku:[Tylko zarejestrowani użytkownicy widzą linki. ]
Stary 14-01-2013, 11:37   #4
websterek
Model: Focus C-Max
Rocznik: 12/2005
Postów: 11
Napisał petrus1 Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Dziękuję za pomoc. Zmieniłem język na polski.
Mniej ważne funkcje
Wyprodukowano w fabr.w Saarlouis
Zestaw bezpiecznych zamków nr 1
Bez grupy zwiększenia wygody
Zest. mat. market. nr 1
Bez aplik./naklej. SVO
Poziom marketingowy 1
Bez el. uk. stabilizacji toru jazdy
Bez globalnego/automat. zamykania
Ok. przednie zamykane 1 dotknieciem
Z Szybami Tylnymi Sterow. Ręcznie
Ze standardowš przyciemnianš szybš
Bez osł.termicznej szyby przedniej
Bez Ogrzewanej Szyby Przedniej
Z mini-konsolš górnš
Z mala konsola
Bez tylnej konsoli podłog.
Bez spec.apl.wewn.
Z konwencjonalnš podsufitkš
Z pokrywš przestrzeni bagażowej
Z Regulowanym Lusterkiem Wstecznym
Ogrzew. wypukle lusterko kierowcy
Z wypukł.el.ster/ogrz.luster.pasaż.
Z œrodk. zagłówkiem z tyłu
Z ręcznie reg. podporš lędŸ. kier.
B. podpory ledzw siedzenia pasazera
z regulatorem 4-poz.pol.siedz.kier.
Z reczn.2-kier.reg. siedz.pas
Bez sprzegu przyczepy
Kluczyk zapł. ze zdalnym ster.
Z profilowa galka dzwigni zm biegów
Z 2.klucz. zapł.ze zdaln.otw.
Z Centralnym Zamkiem
Z czest.pracy przeryw
Air Crtn Rstrnt LH
Kurtyna powietrzna - prawa strona
Z poduszka powietrzna kierowcy
Z Poduszkš Powietrznš Pasażera
Z bocznš podusz.pow.- str. kierowcy
Z bocznš podusz.pow.- str. Pasażera
Z mocowaniem Isofix
Z małym stalowym kołem zapasowym
Ze Standard.Amortyzatorami Tylnymi
Koło ze stopu 6.5 x 16"-Styl A
Nieblokujšce nakrętki kół
Z Zawieszeniem Standardowym
Z mechanicznym hamulcem postojowym
Ze wspomag. awaryjnym hamulców
Układ ABS na wszystkie koła
Bez osłon ochronnych
Standardowe siedzenie przednie
Ze stałymi pedałami
4-ramienna kierownica skórzana
Ze Sterowaniem Prędkoœciš
Z dod. nagrzewn.
Konwencjonalne wskaŸniki - Poziom 2
Z prędkoœciom. km/h
Z ukladem wspomag.przy parkow.tylem
Bez zestawu do zamontowania radia
(+)RDS
Bez gniazdka A/V
Z antenš œrodk.
Wyp.podst.CD + Radio AM/FM
Pakiet wyposażenia systemu ICE 2
Z 6 glosnikami
Bez ukł. zapewn.rozrywki rodzinie
Ze Sterow.Radiem Na Kolumn. Kierown
Z autom. reflektorami
Z reflektorami halogenowymi
Z Przednimi Lampami Przeciwmgieln.
Bez regulacji ustaw. reflektorów
Czasy w strefie GMT +1. Teraz jest 11:46.
