Zobacz wyniki ankiety: Którą wersję softu Converse+ PDC skończyć jako pierwszą
Przedliftową 195 63.31%
Międzyliftową 23 7.47%
Poliftową 90 29.22%
Głosujących: 308. Nie możesz głosować w tej sondzie
Stary 29-10-2014, 22:08   #521
motral
Domyślnie Odp: Schemat podłączenia Converse+ poszukuję
Hi Orion, I did not see no one video of your PA functionality,
How did you solve refresh rate of UI or out of PA CAN command in firmware,
ACC compatibility, stole my firmware?
Alex
  Odpowiedź z Cytatem
Stary 29-10-2014, 23:09   #522
Postów: 18,052
Alex, not only you found Ford software for the Chinese converse+ ... Not only you have access to IDA Pro ... Generally - this is not "yours" software: 95% of code is taken direct from Ford...
More faith in people ... Orion's Software works better with ACC than yours and has better refresh rate on 1007. I know both of the software. The Orion's software at this moment don't support of PTC.
Within a few days we will make films specially for you!
I think - orion can answer for all your technical questions.
Ostatnio edytowane przez tedi_k ; 29-10-2014 o 23:12
Stary 30-10-2014, 00:58   #523
orion512
Avatar orion512
Zarejestrowany: 23-04-2013
Model: Ford S-MAX
Silnik: 2.0TDCI 140->163KM
Postów: 1,241
Napisał motral Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Hi Alex
I do not have any videos but I have a lot of pictures
Why do you think I stole your firmware? Writing it cost me almost a year of hard work. Of course I was based on the Chinese version preFL and FL. I had to hardware modify a European converse to run the Chinese firmware on it. Long time I analyzed the CAN frames on MS bus. I wrote a PAM module simulator to test the firmware. PDC freshrate I have about 10 frames per second and I will not have a problem with counting average speed. I also managed to run PDC on a 1507 firmware. I have not seen this functionality in your software.
Bump:
A wracając do ikonki tempomatu to dzięku uprzejmości kolegów dobo raz alecki mamy kilka propozycji do wyboru. Było trochę rzeźbienia ale udało się je wrzucić. Ja mam już swojego faworyta ale chętnie wysłucham też waszych opinii. Poniżej obrazki.
Typ Pliku: jpg DSC05265.jpg (96.3 KB, 339 wyświetleń)
Typ Pliku: jpg Tempomat galeria.jpg (33.3 KB, 706 wyświetleń)
Ostatnio edytowane przez orion512 ; 30-10-2014 o 01:17
Stary 30-10-2014, 06:30   #524
tombalt
Avatar tombalt
Imię: Tomasz
Zarejestrowany: 31-08-2011
Model: S-MAX ST / Focus Active, wnętrze Vignale
Silnik: 2.0 TwinTurbo/1.5 EB
Rocznik: 2020/2020
Postów: 1,601
Domyślnie
Stawiam na 12
S-MAX: AmbientLEDx25 /CANbox /Heated 2nd row /2nd USB HUB /DSP B&O / FullDigital
FOCUS: AmbientLEDx15 /TSR /DAS /AHB /BLIS /CTA /iACC /PCA /NAVI /Alarm /FrontCAM /CANbox /Towbar /WACM /2nd USB HUB /Electric seats x2 /right door lock switch /storage seat x2
tombalt jest offline   Odpowiedź z Cytatem
Stary 30-10-2014, 08:33   #525
Postów: 18,052
Moim zdaniem nr 7 jest bardziej pasujący.
Stary 30-10-2014, 08:55   #526
mayak
Avatar mayak
Zarejestrowany: 17-05-2006
Model: Smax / Fusion Energy
Rocznik: 2019 / 2017
Postów: 5,353
moim zdaniem trzeba patrzeć na ikonki z drugiego obrazka, bo rozmiar lepiej odpowiada temu co się widzi zza kierownicy
i z tego obrazka mi podoba się pogrubiona wersja 12stki czyli 13tka Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
ps.
dobra jest też 9 bo większa
mayak jest online   Odpowiedź z Cytatem
Stary 30-10-2014, 09:04   #527
Alecki
Avatar Alecki
Zarejestrowany: 05-03-2004
Model: C-MAX MK2, S-MAX MK2
Silnik: 1.6EB, 2.0EB
Rocznik: 2011, 2017
Postów: 1,591
Orion,
a możesz wrzucić bitmapę w formacie bezstratnym? Odnoszę wrażenie, że jpeg rozmywa krawędzie.
"...szybkości jazdy drogowej nie mierzy się prędkością ani czasem. Mierzy się ją ryzykiem. To ono wyznacza granicę. Jeśli ryzykujesz na drodze, obojętnie ile pokazuje licznik – jesteś lekkomyślnym frajerem " [K. Hołowczyc]
Alecki jest offline   Odpowiedź z Cytatem
Stary 30-10-2014, 09:10   #528
dobo_28
Imię: Artur
Zarejestrowany: 31-08-2012
Model: S-MAX, YARIS
Silnik: 2.0 FFV Pb + LPG, 1.0 Pb
Rocznik: 2009, 2006
Postów: 310
faktycznie 7 fajnie nawet wyszła, ale jeszcze bym ją lekko zmodyfikował zabrał bym po jednym pikselu na samym dole (te kończące okrąg) oraz środek (mocowanie wskazówki licznika) zrobił bym tak jak w 5 czy 6 bo są takie same lepiej to by wyglądało takie zaokrąglone
w 12 i 13 też bym zmodyfikował mocowanie wskazówki tak jak wyżej
dobo_28 jest offline   Odpowiedź z Cytatem
Stary 30-10-2014, 09:24   #529
orion512
Avatar orion512
Model: Ford S-MAX
Postów: 1,241
Moim faworytami są 5 albo 13. 5 oraz 6 to jest to samo tylko 5 jest o pixel podniesiona. Dwie największe (8, 9) odpadają bo ich rozmiar przekracza rozmiar ikonki.
Stary 30-10-2014, 09:42   #530
Slartibartfast
Avatar Slartibartfast
Zarejestrowany: 10-05-2010
Model: S-Max FL +Mondeo5Vig
Silnik: 2.0TDCi 140KM +180KM
Rocznik: 09.2010 +08.2017
Postów: 1,492
13 najlepiej widać, zwłaszcza strzałkę
Mój Maksik pali [Okleiłem eSia] [Końcówka wydechu] [LEDy]
Slartibartfast jest offline   Odpowiedź z Cytatem
Czasy w strefie GMT +1. Teraz jest 11:54.
